10-18-2022 12:16 AM - edited 10-18-2022 12:21 AM
Hi all,
I am making a DQMH application with 5 modules and a Launcher. My application works perfectly in the LabVIEW environment. But after I have created an exe out of it. It won't even launch. I had to enable debugging and this is the error it shows up for the Start Module through the launcher. I am attaching the Start Module and the Launcher for reference.
Solved! Go to Solution.
10-18-2022 12:41 AM
This is a well know issue. If you receive this error message when you try to launch the DQMH module, you have to check all the Controls and Indicators of your main.vi.
=> All typedef controls files must be public!
If you have nested modules, then you have to check them as well!
See also my checklist for DQMH/PPL
best
Claude
10-18-2022 10:58 AM
I'd also check any Conditional Disable Structures in your code to see if any of them contain broken code in the RUN_TIME_ENGINE==True frame (or the Default frame if the enabled frame in the IDE is RUN_TIME_ENGINE==False).
10-18-2022 07:48 PM
Thanks a lot Darren. It was code written by someone else that was causing the issue and yes it was in a DDS with RUN-TIME set true with a broken wire.
