Having trouble running my Build.
Hi all,
I am making a DQMH application with 5 modules and a Launcher. My application works perfectly in the LabVIEW environment. But after I have created an exe out of it. It won't even launch. I had to enable debugging and this is the error it shows up for the Start Module through the launcher. I am attaching the Start Module and the Launcher for reference.
(1,164 Views)
This is a well know issue. If you receive this error message when you try to launch the DQMH module, you have to check all the Controls and Indicators of your main.vi.
=> All typedef controls files must be public!
If you have nested modules, then you have to check them as well!
See also my checklist for DQMH/PPL
https://forums.ni.com/t5/DQMH-Consortium-Toolkits/my-DQMH-PPL-and-VILIB-PPL-best-practices/td-p/4155...
best
Claude
CLA / CTD
(1,138 Views)
Accepted by VBajaj
I'd also check any Conditional Disable Structures in your code to see if any of them contain broken code in the RUN_TIME_ENGINE==True frame (or the Default frame if the enabled frame in the IDE is RUN_TIME_ENGINE==False).
(1,092 Views)
Thanks a lot Darren. It was code written by someone else that was causing the issue and yes it was in a DDS with RUN-TIME set true with a broken wire.
(1,065 Views)
