Get Module ID in Helper Loop Timeout for Cloneable Module
Hi everybody,
I am using a cloneable module with a helper loop to collect sensor data. For this I use the timeout case of the helper loop the determine the refresh rate of the sensors. Because I want to get multiple instances of the same sensor setup I want to use the cloneable module. I am wondering now if there is a possibility to get the module ID in the timeout case of the helper loop to show which instance of the sensors timed out.
I am quite new to DQMH especially to cloneable modules so please apologize if this has a simple solution.
Thanks in advance
(705 Views)
Accepted by Johimi
Hey Johimi,
happy to hear that you're using DQMH for your programming needs.
You can read the clone's Module ID from the Module Admin object by wiring the Module Admin to the helper loop and using a simple property node, see the screenshot:
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (The Future of Team-Based LabVIEW Development)
(684 Views)
