Feature Request: Probe MHL Queue Status
Today I ran into my first instance of what is likely a common problem where my helper loop swamped the MHL with more requests than the MHL could handle because of a hardware problem in the MHL. Since this was my first foray into Helper Loops, it took me a bit to track the problem down, using cumbersome history probes on DQMH Enqueue Message and DQMH Dequeue Message.
What would have helped a lot would be an additional output terminal on DQMH Dequeue Messages that told how many items were still in the queue (using Get Queue Status). A person could ignore this terminal, probe it, or put in some code to check it and generate an error if too many messages built up. If I understand correctly, all that would be needed is a Get Queue Status in DQMH Dequeue Message wired to any of the free terminals. Making this change would not enable any forbidden manipulation of the queue itself; it would simply provide a sometimes-critical piece of information about the health of the module.
Some previous discussions of similar requests are here and here
(375 Views)
Hi FlatCat,
I think you wanted to post this here:
DQMH Consortium Toolkits Feature Requests - NI Community
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
(350 Views)
Thanks, Chris. I've done that.
David
(343 Views)
