06-12-2020 12:39 PM
We just put Antidoc through a project with 22 DQMH modules, 40 libraries, and it generated successfully a 419 pages document.
The most important part is that the tables would be very useful during troubleshooting because I can see where all the requests are called and where the code registers for broadcasts.
Excellent work Olivier!
Fab
07-16-2020 07:51 AM
V1.0 has been released yesterday --> https://wovalab.gitlab.io/open-source/labview-doc-generator/posts/2020-07-15-v-1.0-release/
Enjoy!
07-16-2020 08:17 AM
The architecture graphs are super useful, thanks for this great tool 😉.
01-12-2021 08:12 AM
Version 1.2.0 is available on vipm.io --> more info here https://www.linkedin.com/feed/update/urn:li:activity:6754688226461569024/
03-07-2021 08:42 PM - edited 03-08-2021 09:03 AM
When I use the browser with the plugins enabled, I am able to see the UML diagrams.
but when I export to pdf, I just see the same text in the pdf as I do in the adoc format.
is there a trick to getting the uml diagrams into the pdf?
EDIT: If I use AsciiDoctor to create the PDf, I do not see the UML diagrams. If I use Chrome to view the HTML page (with the extensions enabled), I can use the built in Microsoft Print to PDF to get the UML diagrams, but you lose the ability of clicking on the table of contents to jump to a section like you have in the HTML.
03-08-2021 02:58 PM
Hi Kenny,
First of all, I would say that to obtain a full-featured PDF; the only way is to use the asciidocotor toolchain. So the right question is why you don't get the UML diagram when you use Asciidoctor.
Question: did use the following command to generate your pdf?
asciidoctor-pdf -r asciidoctor-diagram myfile.adoc
This should work.
03-09-2021 02:01 AM
For the record, version 1.2.1 is available on vipm.io. More information here --> https://wovalab.gitlab.io/open-source/labview-doc-generator/posts/2021-02-16-v-1.2.1-release/
03-09-2021 06:50 AM
Ah, ok, thanks for the help on the command.
I had tried running
asciidoctor-pdf basic-example.adoc
from the asciidoctor webpage.
10-27-2021 10:14 AM
Some heads-up about Antidoc:
Olivier
07-04-2022 07:40 AM
I'm adding another channel for those who will be interested in discussing the Antidoc project in a more casual/direct way --> https://wovalab-open-source-projects.zulipchat.com/#
