07-26-2021 09:19 AM
Hi all,
I use a Cloneable Module to control 2 identical stages, say Stage-1 and Stage-2.
I use Helper loop to monitor the real-time displacement change of the stage (program shown below), and name of the Broadcast is Position Updated:
and I registered this broadcast event in another program as below:
When I move Stage-1 and Stage-2 at the same time, I can only get position updates from Stage-1, and My question is How can I get position updates of both Stage-1 (Module ID 1) and Stage-2 (Module ID 2)?
OR say: With Cloneable Module, can I move cloneable hardware at the same time and get its updates at the same time?
Thank you and best regards,
Pacino
Solved! Go to Solution.
07-27-2021 01:03 AM
Hi Pacino,
Yes, you should be able to see both Stage 1 and 2 position data independently. This is assuming that the Ref Stepper is different for both.
I have some questions/suggestions for you:
1) Is Ref Stepper different for both Stage 1 and Stage 2?
2) Are all sub-VIs in your cloneable module set to re-entrant?
3) Does it run from your API Tester?
4) Why are you passing the Wait Notifier and wait for reply down to your helper loop? I wouldn't do this.
5) You can control the timing of your helper loop by changing the "0" in the Wake Up Helper loop case to 200, and then you don't need the Wait VI in the Timeout case
6) Are you sure you have registered events for all clones? ie. Need to make sure both clones have been started and then re-register.
7) In your event handling loop where you receive the broadcasts, I presume there is another case frame for Module ID "2"? If yes, are you sure the other Module ID is actually "2"? You should check what Module IDs you actually have. If you didn't shut them down properly, then you may have an issue here.
Hope this gives you some ideas to try.
07-27-2021 06:10 AM
Thank you Christopher for your reply, very very inspiring! It is very delighted to receive your reply. Please have a look the attached figures showing my issues. I would also like to discuss the Wait Notifier and wait for reply in the Helper loop, but will discuss this seperately after this.
07-27-2021 06:47 AM - edited 07-27-2021 06:48 AM
Your Move Absolute function - is it a Request and Wait for Reply?
If yes, try setting "Wait for Reply" to FALSE.
07-27-2021 08:35 AM
Thank you Christopher,
I set the Move Absolute function Request and Wait for Reply as FAULSE.
Did not solve the problem.
I can only get 1 position update.
Pacino
07-27-2021 09:48 AM
Hey Pacino, is the stage actually physically moving in both x and y direction at the same time? And as Chris said, are you sure about the module IDs? Are you populating the position indicator correctly?
As always, it would probably easier to help you if we had a small piece of example code to look at...
DQMH® (The Future of Team-Based LabVIEW Development)
07-27-2021 05:11 PM
Pacino - are you saying you're not receiving the 2nd broadcast at all, or just not at the same time?
08-03-2021 03:30 AM
Please keep this topic active, I am doing some testing, and if the problem can not solved, I will upload my program code. Thanks!
