Antidoc Add-on: LabVIEW project documentation; custom errors are not generated correctly
I wanna use custom errors in a DQMH-Modul and later generate the documenation by using Antidoc Add-on: LabVIEW project documentation.
Sadly somehow in the generated documenttation the error code and decription is missing.
Custom error in project (with naming *--error.vi) 
The error VI
Here the documenation
Also the documentation of "Module Not running" and "Request and..." is not complete.
Hast anyone the same problems? Must I configure something in the toolkit?
Message 1 of 15
(672 Views)
Hi @-Helmut-,
First, a traditional question: can you check that you're using the latest add-on versions?
Antidoc should be able to retrieve the error number and the string constant's content for all the error vi style described here. Your screenshot seems to show a code supported by the addon.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 2 of 15
(648 Views)
Hi Olivier,
thanks for your quick response 😊
I checked the versions, should be ok, no updates availlable, see below
At the moment I´m using LabVIEW 2024Q3 64 Bit.
Before I also uploaded the demo project, it would be intersting it it works on your machine
Or have you a small demo were the generating of the documenation works?
Helmut
Message 3 of 15
(631 Views)
Olivier I could swear this has been working previously.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Message 4 of 15
(618 Views)
That's weird!
I have a unit test to check all the code expected to generate content, and it works.
The truth is out there 😐
Olivier Jourdan
Message 5 of 15
(596 Views)
@-Helmut- @joerg.hampel,
How did you create your error VIs?
From scratch or starting with a copy of an existing one?
Olivier Jourdan
Message 6 of 15
(594 Views)
Hi Olivier,
I think I copied a working one like "Module Not Stopped--error.vi".
But also generated errors from DQHM like "Module Not Running--error.vi" are not correct.
Message 7 of 15
(586 Views)
It seems that I have a reproduction case
Can you confirm that the issue is selective? Just a part of your error VI is not working?
Olivier Jourdan
Message 8 of 15
(584 Views)
Yes it looks the same!
Error code = 0 and missing description
Message 9 of 15
(574 Views)
Ok, I think I found the bug.
The issue should happen only on the error VIs containing the `Error Cluster From Error Code.vi` and one or more VIs.
I have to make the parsing code more robust.
@-Helmut-, may I ask you to create an issue in the Antidoc addon project?
Olivier Jourdan
Message 10 of 15
(564 Views)
