DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
Petru_Tarabuta
Small improvement to error message generated inside MHL Default case
Status: New
Accepted.
Using DQMH 7.0.1.1316 (currently the latest version), the error message generated inside the Default case of the Message Handling Loop is "The invalid message string "%s" was received in the Message Handling Loop for module "%s"."
"The invalid message string "%s" was received in the Message Handling Loop of module "%s"." might be a small improvement.
4 Comments
FabiolaDelaCueva
We will review this in the next features review session...
I do like the idea of a more detailed error message.
On a semi-related note, in case you didn't know, the DQMH Validation tools do have a test that checks if you are enqueing a message that does not exist.
Running DQMH Validation via CLI on your CI toolchain can also find this type of dormant bugs.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Petru_Tarabuta
"On a semi-related note, in case you didn't know, the DQMH Validation tools do have a test that checks if you are enqueing a message that does not exist. Running DQMH Validation via CLI on your CI toolchain can also find this type of dormant bugs." - Thanks. I have used the DQMH validation tools through the UI (not the CLI yet), but wasn't aware of this specific check.
joerg.hampel
Status changed to: New
Accepted.
DQMH® (Developer Experience that makes you smile )
Petru_Tarabuta
Thanks!
