DQMH Consortium Toolkits Feature Requests
Darren
Ship 'Barebones' module templates with DQMH
Status: Under Consideration
The exact way of doing this still needs figuring out.
I have 'barebones' singleton and cloneable module templates that I always use when creating new DQMH modules for projects. I started with the shipping module templates and removed:
- 'Do Something' events
- All #Bookmarks
- Simulate EHL/MHL error buttons
I propose DQMH ship with these simple module templates. They help save several minutes when creating a new module. I'm not suggesting changing the project template, but rather simply adding two new options in the Add New DQMH Module drop-down:
I'm open to suggestions for different names. 🙂
3 Comments
Enrique.Noe
Darren, I can not agree more, I also always delete the same, my suggestion would be to create a separate catalog of VIPM packages.
I have 4 different flavors that I always use:
Singleton and Clonable with helper loop.
Singleton and Clonable wit subpanel support.
I can't find a directl traslation to Spanish for the  "Barebone" word so, I would sugest, 'simplified Singleton/Cloneable', 'minimized Singleton/Cloneable', if Barebone makes more sense I don´t mind.
Enrique.
Ozfarmboy
What if these barbones templates became the standard ones, and the original set are relabeled to something like "Singleton (includes guiding text and sample events)".
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
Olivier-JOURDAN
Status changed to: Under Consideration
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
