DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
CyGa
Round trip : add the request arguments in the broadcast
Status: New
Under consideration for a future DQMH release
A round-trip can be summarized as a Request and Reply event + broadcast of the reply.
Round-trips are particularly useful when debugging systems where the access to the module itself is hard to get (like when using TestStand / VeriStand platforms). They are very good sniffers to understand what's going on under the hood.
I would find it very valuable if the broadcast could also carry the request arguments !
This way the 'sniffer' could expose the context of the reply : reply is formed that way when the request contains such arguments.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
5 Comments
Olivier-JOURDAN
Status changed to: Declined
Too specific usage.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Darren
Proven Zealot
I feel like this special use case could be accomplished by the developer by simply copying the request arguments into the reply payload arguments window when first creating the round trip, then wiring them through in the resulting scripted code.
CyGa
A lot of things can be done simply by the developer doing 'things'.
Round trips are mainly used for debugging, and it would help a lot in all debug situation to know the input and output of a code related to a request.
The idea of the automation of that task would also be to wire automatically the request arguments into the broadcast cluster in the MHL case.
Olivier-JOURDAN
Status changed to: Development Started
Olivier Jourdan
mbaudot
Status changed to: New
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
