DQMH Consortium Toolkits Feature Requests
Olivier-JOURDAN
Move Stop Module.vi next to Start Module.vi in the library hierarchy
Status: Accepted
IMHO, it would make more sense to have the Stop Module request at the same level than Start and Sync functions.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
3 Comments
Jens_S
Well I have to say that I disagree with this. The Start Module VI is not a DQMH request at all so it's separated from the other build in request like Stop Module. At first I also found this a bit confusing but it makes sense if you think about it from a DQHM point of view.
Olivier-JOURDAN
@Jens_S, the stop module is a request, yes, but the code doesn't look like all the other requests.
Moreover, I'm not sure the hierarchy needs to follow the nature of the code. For me, that's more a kind of palette organization. In this way, it makes sense for me to have the start and the stop at the same level.
Olivier Jourdan
mbaudot
Status changed to: Accepted
Matthias Baudot | Software Architect | Founder at STUDIO BODs
STUDIO BODs     BLT for LabVIEW     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
