DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
Darren
Debugging Improvement - Optionally show DQMH Main VI diagram on initialization
Status: Released
I use the Show Diagram debugging request on DQMH modules all the time. But sometimes it's not quite enough, like if there is a bug in my module *initialization*. By the time I fire the Show Diagram request, there is no way for me to debug the initialization problem. And when I say "initialization", I'm not only referring to the Initialize message in the MHL, but also all the code on the left side of the diagram that executes before we even get to the EHL and MHL.
I propose the following:
1. Add a new data member to the Module Admin class: "Show Diagram on Init"
2. Add a new input to Start Module.vi that sets this flag on the Module Admin class that is passed to the Main VI. Default is FALSE.
3. In the Main VI, if this flag is true, then Init Module.vi will show the diagram of the main VI on initialization AND turn on Retain Wire Values.
With these changes, the block diagram of the Main VI will appear immediately on init, and we can probe any wires on the diagram that executed during initialization to see their values.
It would be nice if there were a validate+fixer for this, but given that it is a debugging feature (as opposed to a change in framework behavior), I'm fine if there is no validate+fixer.
2 Comments
Olivier-JOURDAN
I love the Retain Wire Values part of this idea 🙂
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
