DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
benjamin-hinrichs
Clonable Template: Adressing non-existing Module ID should raise error
Status: Declined
When working with clonable modules it is possible (although not desired) to address a Module ID instance that doesn't exist (e.g. has already been closed, never existed in the first place). All clones would ignore said request and in the best case you'd see a timeout error. This may bring about unexpected bugs, especially when working with Requests (without reply).
I think the request should check if Module ID exists and throw an error if it doesn't. This could work by modifying the Request and Request with Reply template to the following:
I propose to add such functionality to the DQMH Clonable Template and check for this in module validation.
Although I've been 10+ years long fan of LabVIEW, I started to discourage engineers to start new projects in a SaaS language. NI must first regain trust within its community.
2 Comments
Olivier-JOURDAN
I was about to Kudo, but I'm worried about the overhead that could occur. I don't think this deserves it.
I get your use case, but I think it should be handle locally.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Status changed to: Declined
Olivier Jourdan
