DQMH Consortium Toolkits Feature Requests
joerg.hampel
Add "local" events for helper loops (esp. in cloneable modules)
Status: Released
This feature request is adding to the already existing "Private Request" and "Helper Loop Creation" requests (or not?):
When working with helper loops in cloneable modules, it would be nice to have a way for sending messages from the MHL to the helper loop which doesn't need the module ID, and which doesn't interfere with other clones' helper loop timings. I'd still like this new mechanism to look and feel like the regular events, with all the scripting and other goodness.
Maybe instead of calling them private events, a better name would be "local" events (which would, of course, be set to private scope).
DQMH® (Developer Experience that makes you smile )
3 Comments
ChrisFarmerWIS
Interesting suggestion.  Just yesterday, I experimented with using channel wires to pass an event from the MHL to the HeL (Helper Loop).  I didn't spend long on it yet - trying to work out if I can blend the events generated by the channel wire with the Stop Module event - no luck yet - not sure if this is even possible.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
doyles
I would second calling them Local events as that is a good distinction from a standard DQMH event that has been changed from Public to Private and is expected to be handled through the EHL of the module versus being created explicitly for a helper loop.
