DQMH Consortium Toolkits Feature Requests
Enrique.Noe
Add an additional Parameter to 'Get DQMH Modules in Project.vi' to search under dependencies.
Status: New
Hi, I would suggest adding a boolean called 'Include Dependencies' to the function on the scripting API to search for DQMH modules on the project, sometimes we have projects and we call DQMH Modules not listed on the project itself, but the developer should be aware we are calling those DQMH modules under dependencies, the Panther Dashboard for DQMH already is searching for DQMH modules under dependencies but it would be great if the native function does this functionality, also, I suggest adding a boolean array output to know if the resulting modules are located under dependencies or they are in the project.
This is how I visualize the connector pane of the 'Get DQMH Modules in Project.vi'
Thank you!.
CLA Enrique Noé Arias Software development is, at its core, all about problem-solving. I can help you go further, faster, and enjoy the process.
I'm attending the GLA Summit!
1 Comment
Enrique.Noe
Regarding this Feature request, I would also suggest to add the target as parameter to this possible upgrade.
