DQMH Consortium Toolkits Feature Requests
TiTou
Add a sequence diagram logger
Status: Released
Lumos is the solution: https://dqmh.org/lumos
It can be hard to follow the flow of messages between DQMH module in a large project.
I find sequence diagrams great to document that, one tool that would rock is something that looks like a UML Sequence Diagram that is updated as messages are being sent. Columns generated the first time a module is started and then the lifelines of the modules are generated and terminated in their column.
Such a tool was created for the AF, so surely the same could be done for the DQMH.
Epictetus
Antoine Chalons
4 Comments
dwackerbarth
I would also like to see some sort of program flow module that the developer or the user can view during run time that TiTou was commenting on. I created one for a simpler QMH that showed in a spreadsheet form, the events produced by the producing module+case and the events consumed by the consuming module+case. It also showed how many queues are on the stack for each module. This was very useful for troubleshooting the code for new developers inheriting the code. A developer or user could clear the log, press a button and watch program flow. The module also had an option to save this data to an Excel file. Below is a front panel view of the module.
I'm new to DQMH and would like to say "What a cool tool" and hopefully I'm not missing something.
FabiolaDelaCueva
Dwackerbarth,
Have you tried right-click on an event structure and using the event inspector while the program is running?
Titou,
This is in my wish list for features for DQMH. We will see if we get there one day.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Olivier-JOURDAN
Status changed to: Development Started
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
mbaudot
Status changed to: Released
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
▶ Check out my LabVIEW presentations and videos!
