Hi Chris
The SUD?s are a self-contained VBS unit to create scriptable dialogs. To communicate with the VBScript ? where it is called from ? you must use DIAdem variables or self defined user variables. In your case the special variable type enumeration (Größenliste) could solve your problem. The enumeration variables are string variables defined in a text file.
I hope this will help you.
Greetings
Walter
