DIAdem
report wizard keeps coming back
I have disabled the report wizard at startup many times (in settings-desktop parameters-general-report wizard), but every time I start DIAdem, the wizard comes back and the settings are undone
any idea what is going on?
Seriously concerned about the Labview subscription model
(3,407 Views)
When you turn off the report wizard at startup, it will disable it for the current DIAdem session, i.e. until you close DIAdem. It will still be on when you start DIAdem the next time.
To turn it off permanently, follow these steps:
1. Turn off the report wizard (in settings-desktop parameters-general-report wizard)
2. Select the 'Window' menu and then choose 'Close all'
3. Either click on the blue disk icon (labelled "Save desktop") or chose the "File" menu and then "Save settings ..."
4. Overwrite your "*.ddd" file typically "desktop.ddd" with the new settings
Done.
From now on, the Report Wizard should no longer show up.
Please let me know if this helped.
Otmar
Otmar D. Foehner
(3,407 Views)
Thanks Otmar!
Couldn't be any clearer and it helped me get a much better understanding of DIAdem's file managment in the mean time. Much appreciated
(3,407 Views)
