When you turn off the report wizard at startup, it will disable it for the current DIAdem session, i.e. until you close DIAdem. It will still be on when you start DIAdem the next time.
To turn it off permanently, follow these steps:
1. Turn off the report wizard (in settings-desktop parameters-general-report wizard)
2. Select the 'Window' menu and then choose 'Close all'
3. Either click on the blue disk icon (labelled "Save desktop") or chose the "File" menu and then "Save settings ..."
4. Overwrite your "*.ddd" file typically "desktop.ddd" with the new settings
Done.
From now on, the Report Wizard should no longer show up.
Please let me know if this helped.
Otmar
Otmar D. Foehner
