04-01-2019 07:19 AM
I am having issue reading eTime format channel values in a data plugin. I am opening a TDMS file and trying to access values in the time channel. But it simply skips all the subsequent steps in the subroutine when it encounters a command like
Root.ChannelGroups(1).Channels("Timestamp").Values(1)
A similar issue with eString channels was fixed by creating channel properties for each value in the channel and reading them out. But unfortunately the channels().Properties.Add command has NO parameter to pass the required data type. By default, it is the data type of the channel. Hence, for the Time channel, I am unable to read the channel values added as channel properties.
Is there a way to convert the data type of the eTime channel to eString?
Another issue is that inside a plugin, the Custom Root properties in the original (tdms) file cannot be accessed, as Store Elements can either by of group or channel type. Only Group and channel properties can be. How to access Root properties?
04-03-2019 01:42 AM
In case of TDMS the root is just the first DataStoreElement.
So it would be
dim rootO : set rootO = FromStore.Children(1)
or just like in the attached example.
The time values are accessed using an usiTimeDisp object. So you can not assign them with '=' but you net to use set.
Check help for UsiTimeDisp object.
Example code:
Option Explicit Sub ReadStore(FromStore) Call FindAndCreateGroups(FromStore.Children) End Sub Sub FindAndCreateGroups(StoreElements) Dim StoreElement Dim TDMGroup For Each StoreElement in StoreElements If StoreElement.IsKindOf(eStoreChannelGroup) Then Set TDMGroup = Root.ChannelGroups.Add(StoreElement.Name) Call TDMGroup.Properties.AddProperties(StoreElement.Properties) Call CreateChannels(StoreElement, TDMGroup) Else ' tdms starts with root and there is only one of them dim timeVal : set timeVal = StoreElement.Properties("datetime").Value ' Object: UsiTimeDisp Call root.Properties.Add("root_timeProp", timeVal.VariantDate) if StoreElement.Properties.Exists("My_prop") then dim MyProp : myProp = StoreElement.Properties("My_prop").Value end if Call FindAndCreateGroups(StoreElement.Children) End If Next End Sub Sub CreateChannels(StoreGroup, TDMGroup) Dim StoreChannel ' Object: ElementWithValues <DataStore> For Each StoreChannel In StoreGroup.Channels if 30 = StoreChannel.DataType AND 0 <> StoreChannel.Size then ' 30 == DataTypeDate dim channelTimeVal : set channelTimeVal = StoreChannel.values(1) call TDMGroup.Properties.Add("channelTimeValue", channelTimeVal.VariantDate) end if Call TDMGroup.Channels.AddStoreChannel(StoreChannel) Next End Sub
