DIAdem
parameter for report title
I have a report with many pages and I need the same title on every page. To do so, I would like to use a parameter which could be defined by the user through a VBS inputbox and then reused on each page.
I tried something with scalar parameters : B1, B2, B3... (see attached file) but I don't know how to change their values. Is it possible to do it this way? Otherwise, do you have any other method?
Thank you in advance for your support
Jérémy
(5,032 Views)
Accepted by topic author Jeremy_TCL
Hi Jermeny,
I'd recommend you write the user's typed Response to the Root.Description property.
Response = InputBox("Enter Text")
Data.Root.Properties.Add "Description", Response
Then in your REPORT header textbox you can use @@Data.Root.Properties("Description").Value@@
Brad Turpin
DIAdem Product Support Engineer
(5,014 Views)
Hello Jeremy,
In addition to Brad's suggestion with the properties, have a look at the "Master Layout" function in DIAdem.
A Master layout allows you to define some standard elements (those could include logos, texts - including variables, boxes, etc.) that will appear on each page of your report in the same location and cannot be edited or moved by the person working on the layout (somewhat like a watermark)
Let us know if you have questions about this function, it's pretty neat ...
     Otmar
Otmar D. Foehner
(5,012 Views)
It's clear now!
Thank you very much
Jérémy
(5,001 Views)
Hello Jeremy,
one helpful variable is also GraphSheetName.
Just add a text box with it (@@GraphSheetName@@) and the name of the current page will be shown on it.
(4,996 Views)
