02-09-2013 05:43 AM
Hi everyone,
I found that in DIAdem Sript we may use the DDEOpen command to open Excel table.
As I try to run the example sript in DIAdem help. It requires to open the excel.exe before it uses the DDE interface.
Is there a way to call Excel from script.
And I always have some DDE error, to say the DDE server doesn't react to the DDEOpen command, even if I've open an excel sheet.
Any suggestions?
02-09-2013 03:23 PM - edited 02-09-2013 03:24 PM
Hello wilburwu
I am far from being a programmer, but this seems to work to open an empty Excel workbook from DIAdem:
Dim Excel 'Excel object variable Set Excel = CreateObject("Excel.Application") Excel.Visible = True ' Starts Excel Excel.Workbooks.Add ' Creates a new Excel document
Maybe this will get you on the right path ...
Otmar
