DIAdem
noise signal detrending through a mathematical method
I'm new here. I have measurement data (deformation of a building) that contains a noise signal that results from the temperature. The temperature is also available. My task is to use a mathematical method to eliminate the interfering signal How could I best eliminate them?
Message 1 of 9
(2,619 Views)
Find the frequency of the noise and eliminate it using a filter.  Need a lot more info and example signals to tackle your problem
Message 2 of 9
(2,559 Views)
Thank you for your Answer
Sensors were placed on a bridge to measure the deformation. These sensors provide the deformation over a certain time. The problem is that in the measured deformation part from the temperature is located, which is subordinate and must be filtered out. The temperature was also measured and exist.
I have two Photos attached
Message 3 of 9
(2,533 Views)
This is just images without data... Could you run FFT on both channels to see which frequency needs to be filtered out?
Message 4 of 9
(2,512 Views)
I wanted to upload the Diadem file but I could not
Do you know why?
Message 5 of 9
(2,499 Views)
Hello
i have attached the file belw
Message 6 of 9
(2,483 Views)
Is that expected to look something like this?
Message 7 of 9
(2,465 Views)
I don't think so.
My task is to find a mathematical method to eliminate the Influence of temperature on deformation. The Compensated signal would have to be like the Original one but with low fluctuation.
Message 8 of 9
(2,451 Views)
Hi Mah,
Wouldn't a low-pass digital filter catch the slow deformation induced by temperature changes?  Say anything less than 5 Hz?
Brad Turpin
DIAdem Product Support Engineer
Message 9 of 9
(2,379 Views)
