DIAdem
need a user dialog screen update while code is running to show some messages
Hi all,
I do some data analyzing in a script. These job needs several minutes, so i want to show in an text box some informations abaut the state of the progress.
Writing some text from script in a dialog box is not the problem. Only the sreen updating on runtime doesn't work.
did somebody have a idea to solve this problem?
thanks
(2,482 Views)
Accepted by topic author MarioRindfleisch
Hi MarioRindfleisch,
You need a non-modal dialog box for this. Here is an example:
dim iLoop
for iLoop = 1 to 5
  call MsgBoxDisp("My Text " & str(iLoop), "MB_NOBUTTON",,,, true)
  call pause(3)
next
call MsgBoxCancel
This is also possible for SUD dialogs. In this case, please have a look at the DIAdem help for “SUDDlgCreate”.
Greetings
Walter
(2,443 Views)
Thank you, 🤔sometimes the solution is so simple😂
(2,434 Views)
