Sorry, but this is not possible without manually programming in VBS. The command DIRLSTWRITE contains a parameter variable: FileLstFilter which specifies which information DIAdem saves when it performs the DirLstWrite command.
onlyFilenames: Only filenames
onlyDirectorynames: Only folder names
filenames: Filenames and file extensions
fullFilenames: Complete filenames
With this parameter you can create a list of sub folders to use them with DIRLSTWRITE again.
I hope this will help you
Greetings
Walter Rick
