01-16-2018 07:46 AM
hii,
I have a channel with temperature values, but the sensor has issues and it gives sometimes 2^16 as max value.
I want to filter this value from my channel , but did not find Analysis tool where I can filter based on Limit.
is there any way to set the max or "in range " Limit for a channel in the Analysis tool set.
regards
Akshay
01-17-2018 12:40 AM
Hi aparab,
You can use the channel event functions in ANALYSIS.
Condition fulfilled is the original channel and condition not fulfilled is NoValue or any other value
Lower limit = NoValue means all values below the upper limit
Greetings
Walter
01-19-2018 05:39 AM
thanks a lot, Walter
regards
Akshay
