DIAdem
diadem is not working
It works even without refresh button very well.  But problem still there.  Message 5.
Thanks.
Message 21 of 25
(3,417 Views)
Hello
Really, if that TDR is able to make a PDF file, then the LV vi I sent should make it as well.
Have tried all the basic's I know.
I did attach the PDF file I made from the VI just to show you how it will look once it works.
Paul
Message 22 of 25
(3,411 Views)
Pdf report little different. Very strange.
Message 23 of 25
(3,407 Views)
please try the default settings of the DIAdem Report VI like this:
(Set Built-in layout template to "XY Graph (landscape)")
Result: myReport.pdf => LV 2012, DIAdem 2012 SP1 both english version
Does it work?
When not please start DIAdem and try again.
Please also try the following modification of "lv_diadem_01.vi":
(The option "Delete DIAdem contents" is initialized with "true")
My result pdf is similar to the screenshot above.
Does it work on your machine?
Message 24 of 25
(3,377 Views)
Hi, it doesn't work.
Spoiler
Message 25 of 25
(3,364 Views)
