Hi Chris
If you would like to import ASCII data into DIAdem you can use the ASCII-Import-Wizard. In tree steps you can define the structure of your data file and save this information in a configuration file (*.STP). If you have a lot of files (with the identical structure) like this one and you only want to load the same information like before than you just need the STP file to load it easily and quickly. In VBScript's you can use the following commands:
T1=Pfad+'abc.asc'
T2=Pfad+'def.stp'
call ASCIIAssocSet(T1,T2)
call AsciiLoad(T1,0)
call ASCIIAssocDel(T1,T2).
Maybe this will help you.
Greetings
Walter
