03-06-2019 05:50 AM - edited 03-06-2019 05:51 AM
Hello
I recently have been issued a new machine from IT department that runs on Windows 10.
Unfortunately all of my report templates have been effected by this change.
It appears that text and formatting objects are now misaligned and I was wondering if anyone else has encountered this problem?
Attached are a couple of images showing the error
I am using DIAdem 2017 SP1 on both machines
03-07-2019 02:28 AM
Hello smoothdurban,
Please, can you upload a screenshot of the printer dialog (W7 and W10) like this:
Are the system default fonts in both OS the same?
Can you also upload the layout and the dataset?
Greetings
Walter
03-07-2019 11:41 AM - edited 03-07-2019 11:42 AM
So I was able to find a solution to my problem
The problem I was having was exclusive to the editbox object. I did some digging online and it appears by selecting a particular option DIAdem.exe properties I was able to remedy the issue.
basically under the compatibility tab I selected to "Override high DPI scaling behavior"
