DIAdem
Viscous Criterion - THOR / WorldSID - IR-TRACC
The Viscous Criterion function in DIAdem (ChnVCCalc) specifies the input data channel to be unfiltered deformation signal in meters. For THOR / WorldSID that uses IR-TRACC, the unfiltered voltage deflections are converted after processing with the respective equations to CFC filtered deflections in mm. In this case can the input to "ChnVCCalc" be the filtered deflection in mm (of course converted to meters).
(2,802 Views)
Hello nabster89
Would you like to give us more context about the configuration you are doing in DIAdem? I could not understand the inputs in this function.
Feel free to attach captures
Regards
(2,766 Views)
Hello nabster89,
you should use the PRE_FILTERED setting when the dummy provides previously filtered input signals.
Additionally it's always useful to activate "Calculate quantity-based". DIAdem will do unit checking and conversion (e.g. mm or m) for you.
Stefan
(2,748 Views)
