DIAdem
Vertical line in a 2DAxisSystem in Report by using a script
I would like to display a vertical line for the y-value where is a difference > 1 of the y-value. This should be done by using a script.
Thank you for your help.
Greetings
Alexander
(776 Views)
Hello Alexander,
Do you mean that you want to calculate the difference from value to value in a channel and if this value is > 1, then you want to draw a vertical line?
Greetings
Walter
(738 Views)
Hello Walter,
That's correct. I compare each value with the one before and if the difference is > 1, a verticle line should be displayed at this position. I have already determined how to determine the position and now need help on how to display the line at this position.
Maybe you know, how i can do this?
Thank's a lot.
Greetings
Alexander
(731 Views)
Hello Alexander,
Please find attached one option to solve this problem.
Greetings
Walter
(727 Views)
