11-04-2020 11:07 AM
User ran into a VIEW layout that crashed when clicking in the graph, after investigating, was able to make something I could replicate it. I set up a script to generate 2 groups of data, and a layout referencing various groups and channels. To replicate the crash, do the following:
Basically, if you manually load a TDV where the Leading Curve on any sheet besides the one that opens by default is set to a curve that does not exist in the currently loaded dataset, DIAdem will crash when you click within a graph on the other sheet(s).
Exceptions (do not produce a crash):
Tested on DIAdem 2019 SP1 and DIAdem 2020
-Josh
Solved! Go to Solution.
12-04-2020 04:46 PM
Hi Josh,
With your VBScript file and VIEW layout, and following your instructions, I was able to exactly reproduce the crash you describe in my DIAdem 2020 SP1.
I have created Bug #1200423 with your description and files.
Thanks for the heads-up,
Brad Turpin
Principal Technical Support Engineer
NI
05-10-2021 03:21 PM
Hey Josh,
I just reproduced the crash you reported with your data creating VBScript and your TDR layout and the directed clicks once more in my DIAdem 2020 SP1. Then I did the same thing in my new DIAdem 2021, and this time the configuration dialog opened up each time in each sheet... looks like the bug was fixed in DIAdem 2021.
Can you verify on your end?
Brad Turpin
NI
05-28-2021 10:36 AM
Yep, looks good to me.
Thanks Brad (and Devs)!
-Josh
