02-04-2019 03:07 AM
Yes, I'm afraid I still get the same error messages when trying this exact line of code. As you say, I can only assume that later versions allow this code to be used without throwing errors.
Thanks for trying.
Regards.
02-06-2019 04:42 AM
Hello Simon,
Just to follow up: I tested the code lines from above on an old DIAdem 11.3.0 installation, this was the result:
Then tried DIAdem 14.0.7, same result:
Trying DIAdem 15.0.2 ("2015 SP2"), the error popup does not show up anymore:
Looks like the behavior was changed between DIAdem 2014 and 2015 SP2, so that's the version you are aiming for, at least.
02-06-2019 08:05 AM
That's very helpful - thank you very much.
Simon.
