DIAdem
User commands
I registered few VBS files in the User commads of DIAdem 9.0. These VBS files create menus on loading the diadem. On clicking any menu created by these registered VBS files, all registered VBS files are re-running again.
(3,057 Views)
Are you calling the user commands that you register on DIAdem startup (using a shortcut with parameters)? I assume you have a script that calls all this registered functions that in turn generate the menus. What is the code behind the menu that is re-running? Are you simply using ScriptStart?.
I tried a similar scenario on my system, but didn't experienced the behavior your are seeing. Can you send me some sample code (as small as possible) for me to reproduce the behavior? Also, please attach the steps that you are following.
Alejandro del Castillo
Application Engineer
(3,057 Views)
