DIAdem
Unwanted waveform feature
Hello all,
My code uses the channel resampling function ChnResampleFreqBased to resample my time and signal channel. Unfortunately it's returning waveform channels, which may be useful in some circumstances but are causing me unnecessary grief (in part because I've never used them so am not familiar with them).
There are some functions to convert channel types from one to the other, in this case WfChnToChn, which converts them to numeric channels. Unfortunately, it produces an X channel, which I don't want and end up deleting.
Can I circumvent all this unnecessary coding by just having the resampling function give me numeric channels in the first place?
Simon.
(4,346 Views)
Hello Simon,
A Waveform channel is a channel that contains the corresponding X information (time, frequency, etc.) as properties, the waveform properties.
This makes an explicit X channel unnecessary and works for equidistant X values. This often makes the handling with channels easier.
That is also the reason why the resampling function results are stored as waveform channels.
Currently there is no way to prevent this.
Greetings
Walter
(4,324 Views)
Thanks Walter.
I solved the problem by using the channel generation and linear mapping functions - less code and I got what I wanted.
The waveform concept may be easier for some applications but it's a shame that DIAdem is provided with a resampling function but not with the choice to just return a simple resampled numerical channel. It feels like the classical ways of working are being ignored even when they are still appropriate....
Regards.
(4,318 Views)
Hello Simon,
I can understand that, depending on the task, a waveform is not the optimal solution. From my point of view, this would be a good suggestion for our DIAdem Idea Exchange Forum.
Greetings
Walter
(4,313 Views)
Agreed, Walter, and submitted.
Regards.
(4,308 Views)
