DIAdem
Transferring from view to report error & receive expanding report error
Hello, I currently have DIAdem 2015 SP2, when I try to transfer any data from the view tab to the report tab I receive the following error.
"Cannot transfer curves into expanding REPORT layouts. Please enter the curves in REPORT manually." Any advice or possible solution would be greatly appreciated.
          Mitchell
(2,790 Views)
Accepted by topic author mitchellc30
Hi Mitchel,
If you open the Layout Parameter dialog in REPORT,
And then the Curve Expansion Mode sub dialog,
And switch off the Expand Curves mode
You will be able to use the transfer function in VIEW without problem.
Greetings
Walter
PS Unfortunately I have only installed a German version of DIAdem 2015.
(2,762 Views)
