05-10-2021 03:01 AM
hi ,
I want to draw a graph like an example.
I need two z-axis and want to know how to add them.
Please explain if there is another way to draw like this example graph.
05-10-2021 05:08 PM
Hi sally,
In DIAdem you can overlay multiple 3d graphing layers, but there is only ever 1 X axis, 1 Y axis and 1 Z axis. Do you really need to see multiple Z axes, or would it be sufficient to see multiple 3d surfaces on the graph? The only workaround is to overlay a second 3d axis system and paint most of it invisible-- that can give you the appearance of a second Z axis-- but only if you never rotate the 3d graph.
Brad Turpin
Principal Technical Support Engineer
NI
05-17-2021 06:45 PM
Thank you.
I'll try as advised.
