03-14-2018 12:47 PM
I have a script that runs through different processes on a dataset. Part of it is a user selected CFC filter.
The data is collected at 400kHz, there are 143 channels. When I select no filter the data saves to approximately 278KB/54MB for the TDM/TDX. When I do select a filter for the data the data saves to 282KB/188MB. While 188MB isn't out of control, it is 3.5 times larger than the unfiltered set. I noticed the filtered dataset carried a few more decimal places, so I truncated, but that didn't seem to make the filesize any smaller.
Any input on this? The only difference between the two datasets is these lines of code:
If FilterClass = 0 Then Call Data.Root.ChannelGroups(GroupNo).Channels(iLoopC).Properties.Add("Filter","Unfiltered",23) Else Call ChnCFCFiltCalc("["&GroupNo&"]/[1]","["&GroupNo&"]/["&iLoopC&"]","["&GroupNo&"]/["&iLoopC&"]","CFC_Free",0,"EndPoints",FilterClass) '-- Filter Call Data.Root.ChannelGroups(GroupNo).Channels(iLoopC).Properties.Add("Filter","CFC " & FilterClass,23) End If
03-15-2018 08:09 AM
I assume you are measuring in 16 bit integer.
After using the filter your data become 64 bit double which causes the increase in size.
May this be the answer to the behavior?
03-15-2018 10:24 AM
That sounds logical, thanks Andreas. Is there anyway to convert back after the filtering?
03-15-2018 11:02 AM
There is a method
Analyze->fx->Quantize
ChnQuantize
That can be used to force a bitness.
Another way is to use
Analyze->fx->Optimize Data Type
ChnOptimizeDataType
which may not work in your case because the filter is really making it float64, so you hav e to force it.
03-15-2018 12:08 PM
Thank you Andreas. This got my file size down to 50MB. As you stated, Optimize Data Type did not work for me (it was what I tried previously).
I wrote this script to quantize the entire dataset to 16 bit:
Dim iLoopC, GroupNo, ChnMin, ChnMax GroupNo = 1 For iLoopC = 1 to Data.Root.ChannelGroups(GroupNo).Channels.Count ChnMin = Data.Root.ChannelGroups(GroupNo).Channels(iLoopC).Minimum ChnMax = Data.Root.ChannelGroups(GroupNo).Channels(iLoopC).Maximum Call ChnQuantize("["&GroupNo&"]/["&iLoopC&"]","["&GroupNo&"]/["&iLoopC&"]",65536,ChnMin,ChnMax) Next
