DIAdem
TDMS Channel Property NI_DataType
I write I16 values to a TDMS channel from LabVIEW. In DIAdem the data type is always float64. The property NI_DataType is read only so how can I set the correct data type ? In fact I have problems because the conversion from I16 to float64 gives me strange results like if I store a sinus my expected negative values will be saved as MaxFloat64 (4.294964939E+09)sinus_cut.jpg
I probed my LabVIEW data and I'm sure that it's ok.
Christian
(4,393 Views)
If I make a explicit type cast to double before writing the data to the TDMS the data looks good. sinus_ok.jpg
(4,389 Views)
Could you post one of the files including the I16?
Greetings
Andreas
(4,387 Views)
