DIAdem
TDM Server 2018 Beta
I have installed the TDM Server 2018 Beta version under Evaluation. When I create an Analysis procedure/Data Finder in the server the process is created but am unable to start them or proceed any further as I get the below warning.
Some components on the server are not running correctly or are reporting an error. See details...
Details
  • The number of configured compute node instances exceeds the number of available licenses. Please open the TDM Server Control Panel, go to Servers - Parallelization, and adjust the number of compute node instances to the number of available licenses. You can look up the number of available licenses in the NI License Manager.
I tried changing the Parallelization but still it does not work. Kindly help me resolve this issue.
Priya
(2,301 Views)
Hi Priya,
Maybe your evaluation license is expired. With the license manager it is possible to extend the default eval period from 7 days up to 45 days. If this timeframe is too small for your tests, please get in contact with the NI sales colleagues.
Greetings
Walter
(2,253 Views)
Hi Priya,
Sorry, my fault. You’re participating the Beta Program. In that case you find some documents on the web (ni.com/beta) and there you find these activation codes:
TDM Server       : L12V86805
DIAdem             : P12A00476
DIAdem-Crash  : P12A00287
You need an online connection for to activate the software. Please let us know if the activation process does not work for you.
Greetings
Walter
(2,239 Views)
Thanks Walter, this helped.
(2,233 Views)
