DIAdem
TDM Header Writer C API: Newer version available?
Hello support team,
we are using in our software the library "nilibddc.dll" for importing TDM data. The library "niTdmHW1_0.dll" is used to export data into the TDM data format. Now, our requirement is to support text channels. The library "niTdmHW1_0.dll" does not support the "STRING" data type but various numeric data types and cyclic channels (implicit). On the other hand, the library "nilibddc.dll" supports the data type "STRING" but only a few numeric data types (UINT8, INT16, INT32, FLOAT and DOUBLE).
Our export must support the following data types:
  • INT8
  • INT16
  • INT32
  • INT64
  • UINT8
  • UINT16
  • UINT32
  • UINT64
  • FLOAT
  • DOUBLE
  • STRING
  • Impilict channel
What is the best way to solve our problem? Maybe, it exists a newer version of the library "niTdmHW1_0.dll" which supports creating text channels?!
Thank you very much for your help.
Henrik
(6,825 Views)
Hi Henrik,
can you please explain a bit what kind of text channel you envision to use:
  1. General purpose text channel
    Each value of the text channel can be different (random)
  2. Assignment / enumeration (text) channel
    The possible channel values are limited and aligned with a numeric (channel) value
(6,762 Views)
What kind of string channels do you want to add?
Are they really free or more like enumerations.
(6,757 Views)
No, the values are not limited. The value count is free and each value of the channel can differ. The character count can be either fixed or non fixed.
For example:
0s -> "Test1"
1,5s -> "Test2"
5s -> "Hello"
The text channel should be some kind of a marker channel (event-oriented).  Its appropriate time channel is not cyclic.
(6,731 Views)
Does anybody have any suggestions about this issue?
I would really appreciate an answer.
Thanks for your help!!!
(6,614 Views)
