‎03-19-2014 11:08 AM
I have a single text file that contains 10 repeats of the same event. I want to overlay each event to check for deviations. I can set flags and copy each event as a separate channel using the time stamp, but these channels need to be created for each text file I open. How do I create such a template without scripts?
‎03-20-2014 10:54 AM
Hi mgb,
I don't think you can get around the need for a VBScript here. What you want is to load the data for each event into a different Group with the X channel values starting at 0 for each Group.
Care to share your data set so we can see what you have to work with?
Brad Turpin
DIAdem Product Support Engineer
‎03-24-2014 07:31 AM
Thanks for the info--time to learn VB!
