DIAdem
Split file into subsets
I have a single text file that contains 10 repeats of the same event.  I want to overlay each event to check for deviations.  I can set flags and copy each event as a separate channel using the time stamp, but these channels need to be created for each text file I open.  How do I create such a template without scripts?
(6,054 Views)
Hi mgb,
I don't think you can get around the need for a VBScript here.  What you want is to load the data for each event into a different Group with the X channel values starting at 0 for each Group.
Care to share your data set so we can see what you have to work with?
Brad Turpin
DIAdem Product Support Engineer
(6,032 Views)
Thanks for the info--time to learn VB!
(5,990 Views)
