Hi jetblack,
By "put headers on my channels after I import the voltages", do you mean you want to populate the channel property fields in DIAdem with the correct info programmatically, or did you mean you want to create a header file (*.DAT, *.TDM) for the existing data file?
Assuming you mean the former, you can use the DIAdem channel property variables (arrays), which all start with "Chn...()" and take a single parameter, either channel number or channel name. Examples are:
ChnName()........... channel name
ChnDim()................. channel unit
ChnComment()......... channel comment
If you instead want to create a header file for your data file, then I'll need to know a bit more about where the data is coming from (binary, ASCII, structure of th
e file, etc.).
Hope that helps,
Brad Turpin
DIAdem Product Support Engineer
