DIAdem
Repeating group calculations for all groups script
Hey all,
I have the attached script to perform calculations on channels in a Diadem group.  I have tried to make it so it will repeat the exact same calculations for every group loaded (each group will have same channels in the same order).  The way I have it now, my code will create i'th number of channels but will perform the calculations always on the first group channels.  Any ideas on how to remedy this?  I tried putting "i" in place of the 1 in the channel group specifications but it seems that location will not accept a varriable ("Ch(""[i]/Supply Pressure (psi)"").
(5,879 Views)
you can use something like this:
("Ch(""[" & i & "]/Supply Pressure (psi)"")
You have to concatenate text (channel name) and variable (i). Use & (ALT+038) symbol for concatenate.
Did it help?
Simyfren
(5,867 Views)
Hi crockengineer,
If you'll post your code as text I can copy and paste, I'll help you make it work on N different Groups.  A data set would also be nice.
Brad Turpin
DIAdem Product Support Engineer
(5,849 Views)
