06-17-2021 07:55 AM
How can I in a script hide and disable DIAdem panel bar buttons. I can access the menu, toolbar, and group bar items, but not the panel bar buttons. See attached visual reference.
06-17-2021 11:45 AM - edited 06-17-2021 11:46 AM
Hi Mark,
I can show you how to remove, reinstate and also hide the main panel items, but I don't see a mechanism to set one to disabled. Here's how you hide a panel icon:
Set ActivePanels = BarManager.Bars("DIAPanels").UsedActionObjs
Set VisPanel = ActivePanels("DIAPanelVISUAL")
VisPanel.Visible = False
Call WndShow("SHELL")
Here's how you remove a panel:
Call ActivePanels.Remove("DIAPanelNAVIGATOR")
Call ActivePanels.Remove("DIAPanelVIEW")
Call ActivePanels.Remove("DIAPanelANALYSIS")
Call ActivePanels.Remove("DIAPanelREPORT")
Call ActivePanels.Remove("DIAPanelDAC")
Call ActivePanels.Remove("DIAPanelVISUAL")
Call ActivePanels.Remove("DIAPanelSCRIPT")
Here's how you reinstate the icons that you've removed:
IF ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels.Remove("DIAPanelNAVIGATOR")
IF ActivePanels.Exists("DIAPanelVIEW") THEN Call ActivePanels.Remove("DIAPanelVIEW")
IF ActivePanels.Exists("DIAPanelANALYSIS") THEN Call ActivePanels.Remove("DIAPanelANALYSIS")
IF ActivePanels.Exists("DIAPanelREPORT") THEN Call ActivePanels.Remove("DIAPanelREPORT")
IF ActivePanels.Exists("DIAPanelDAC") THEN Call ActivePanels.Remove("DIAPanelDAC")
IF ActivePanels.Exists("DIAPanelVISUAL") THEN Call ActivePanels.Remove("DIAPanelVISUAL")
IF ActivePanels.Exists("DIAPanelSCRIPT") THEN Call ActivePanels.Remove("DIAPanelSCRIPT")
IF ActivePanels.Exists("NewPanel") THEN Call ActivePanels.Remove("NewPanel")
IF NOT ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels.Add("DIAPanelNAVIGATOR")
IF NOT ActivePanels.Exists("DIAPanelVIEW") THEN Call ActivePanels.Add("DIAPanelVIEW")
IF NOT ActivePanels.Exists("DIAPanelANALYSIS") THEN Call ActivePanels.Add("DIAPanelANALYSIS")
IF NOT ActivePanels.Exists("DIAPanelREPORT") THEN Call ActivePanels.Add("DIAPanelREPORT")
IF NOT ActivePanels.Exists("DIAPanelDAC") THEN Call ActivePanels.Add("DIAPanelDAC")
IF NOT ActivePanels.Exists("DIAPanelVISUAL") THEN Call ActivePanels.Add("DIAPanelVISUAL")
IF NOT ActivePanels.Exists("DIAPanelSCRIPT") THEN Call ActivePanels.Add("DIAPanelSCRIPT")
IF ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels("DIAPanelNAVIGATOR").Reset
IF ActivePanels.Exists("DIAPanelVIEW") THEN Call ActivePanels("DIAPanelVIEW").Reset
IF ActivePanels.Exists("DIAPanelANALYSIS") THEN Call ActivePanels("DIAPanelANALYSIS").Reset
IF ActivePanels.Exists("DIAPanelREPORT") THEN Call ActivePanels("DIAPanelREPORT").Reset
IF ActivePanels.Exists("DIAPanelDAC") THEN Call ActivePanels("DIAPanelDAC").Reset
IF ActivePanels.Exists("DIAPanelVISUAL") THEN Call ActivePanels("DIAPanelVISUAL").Reset
IF ActivePanels.Exists("DIAPanelSCRIPT") THEN Call ActivePanels("DIAPanelSCRIPT").Reset
Brad Turpin
Principal Technical Support Engineer
NI
06-17-2021 11:59 AM
Don't forget the ever handy BarManager.Reset
06-18-2021 06:53 PM
All worked perfectly. Thank you for the helpful example code.
