11-17-2020 07:29 AM
I have a problem with displaying the data came from csv file.
My system produces the data in the form like below:
Timestamp,BlockID,AlertID,Block Name,Block State,Description,Trigger
556,0x4056,0x95,BlkSrvL2Alerts,OK,MOTOR_CURRENT_SENSOR1_FAULT,Unknown
560,0x4056,0x94,BlkSrvL2Alerts,STOP_UNDF,MOTOR_CURRENT_SENSOR2_FAULT,Unknown
etc.
So: denary number, hex number, hex number, string, string, string, string
So far only one parameter which is displaying is denary number, the legend of the rest parameters is gray-out on the chart.
Is it possible to display the data from my csv files? How to do this?
11-19-2020 10:46 AM
Hi MimiKLM,
I can't find a way to does this directly, I think the way around this would be to use the script to read the the channels and convert to a different format. The steps i would do are:
There maybe be a plugin that does that already, but I havent looked. For the strings, I don't know. What information do you have in the strings?
For creating the script, these links should help:
11-19-2020 10:50 AM
Fault statuses & fault sources
12-02-2020 04:49 PM
Hi All,
If this file with the status values and the hex codes is actually a CAN log file, then you should use the Bus Log Converter in DIAdem to turn it into a TDM/TDX file of scaled and datetime-stamped channels, with each group containing all the data from one message.
Brad Turpin
Principal Technical Support Engineer
