DIAdem
Object required in 'CNO(...)'
This is my first time using  DIADEM and VB scripting, apologies in advance, if my question does not make more sense. In the below line of code, i am looking for "If The Definition channel is present or not "
If CNo(GroupTxt & "id_"& TempEmisType & TempChnStr & "Definition_").Properties("Unique_Definition").Value>0 Then
but, its throwing the error saying: Object required :'CNO(...)'
for your reference the above variables hold this values :
GroupTxt  1,
TempEmisType - emissions
TempChnStr-stream
And when i am using the old code, which i need to do certain modifications but majority of syntax is same, its still working, old code is:
If CNo(GroupTxt & "Ad_"& TempEmisType & TempChnStr & "DefinitionUnique_")>0
Any help is highly appreciated.
Thanks in Advance
(2,270 Views)
Accepted by topic author Kandukuri_raghavendra
The upper code does not work because CNO(...) returns a numeric value back and not a group or a channel so
on a numeric will not work. However, you can use the numeric you get back from CNO(...) to get the group and the use ".properties" on it.  Try:
If Data.Root.ChannelGroups(CNo(GroupTxt & "id_"& TempEmisType & TempChnStr & "Definition_")).Properties("Unique_Definition").Value>0 Then
http://zone.ni.com/reference/en-XX/help/370858M-01/functions/functions/cno/
(2,244 Views)
Thank you @gsklyr, will try it.
(2,236 Views)
