I support the idea of cleaning up the file before importing it. Having commas and dots mixed up is a really unusual situation, and should be managed before the file is imported to DIAdem or any other tool.
Are you using VB or Python scripts? With python, you can easily do it as follows:
# Origin and Cleaned File
txtFileOrig = r'D:\MyFolder\XX.txt'
txtFileCleaned = r'D:\MyFolder\XX_cleaned.txt'
# Open Origin File
with open(txtFileOrig, 'r') as f:
txtStrOrig = f.read()
# Clean Origin File
txtStrCleaned = txtStrOrig.replace(',','.')
# Write Cleaned File
with open(txtFileCleaned, 'w') as f:
f.write(txtStrCleaned)
With this code, you open XX.txt file, replace commas with dots, and save it as XX_cleaned.txt.
If you want to overwrite the original file, just set txtStrCleaned = txtStrOrig
If you are using VB, there is certainly a way to do it, but I should do some research (I am not that familiar with that language, but hopefully someone else will be able to give you a hand).
