I use DIAdem File Write in LabVIEW to save data in DIAdem format. For each device under test(DUT) I create a folder which should contain data of all different tests performed on this DUT with separate header and data files.
The problem is that we have to use file names like:
AAAAAAA.123.123.123.01.1 Test1.dat
AAAAAAA.123.123.123.01.1 Test2.dat
If I use such file names as data path input of DIAdem File Write in LabVIEW, the binary r64 files' names are truncated after the first ".".
For the example names above I get only one binary file named "AAAAAAA.r64" instead of:
AAAAAAA.123.123.123.01.1 Test1.r64
AAAAAAA.123.123.123.01.1 Test2.r64
Of course, DIAdem extracts the data for each test well as the header file points to the
correct data (I assume). But I'd really like to have separate r64-files, too.
Would be nice if somebody could help me..
Andreas
